Hard disk indicator led question
DeadByDawn
One day my hard disk led stayed on continuisly. There is no blinking or anything showing activity. It was just on.
I checked the disk io and it seems normal.
Any suggestions?
Thanks
If it does this right after you boot your system, it's because of Superfetch. It's loading files into your ram so they load quicker.
It may also be that you have Windows Defender scanning the system or some other type of spy ware/virus scanner running.
Next time this happens, keep an eye on what programs are in your notification area.
check to see if your hd led is hooked to your power on led connector, dont laugh i've done it.
