Hard disk doesn't show in device manager, although it works.
sram
I have this hp compaq d530 sff machine at work that I decided to play with a little. It is placed in the resting area and used only for the internet. It had a wd drive partitioned into two partitions. The two partitions have no problems, however, the drive doesn't show up in device manager, nor disk management. If I right click and select properties, choose hardware, it won't show me the name of the drive like it should. It is a weird thing. Now, if I want to--for example--install windows 7, it won't detect any drives to install to. The machine is old and having 7 won't be a wise move, but I want to try it anyway.
What do you think the problem is? I haven't seen this before! I don't think something is disabled in BIOS. Maybe something is done in windows as a security measure?
This is the machine:
http://h20000.www2.hp.com/bizsuppor...dTypeId=12454&prodSeriesId=316720&lang=&cc=us
So the machine runs and boots off the drive, but it doesn't show up in the device manager?
Is it running a RAID card or HBA? because that would explain why it isn't recognized by the install and its probably under a different category than disks in the device manager.
Double click My Computer, right click the drive you want to examine, goto properties
Next click on the "Hardware" tab, that will tell you what its running under.
Yes
No
i already said I did that. Nothing shows up at all, which is puzzling me!
It is something in windows that prevents the drive from showing.
When I tried to install 7 I did it from within windows. However, when I booted
from the cd, the drive was detected. Anybody aware of a security option that
does such a thing? I tried local services in administrative tools but nothing there
seem to have anything to do with it.
