Hangups
Vriess
m7ncg
512 megs mushkin 3200
xp 3200
9600 pro
I just built myself a new xp 3200 box and I thought everything was running ok but I experience hangups in windows and in games(also had problem starting games up). I thought that the latest nforce drivers from nvidia would fix these strange problems but after I installed them I would get even more lockups in windows (before almost none). Does this sound like a chipset problem? I cant seem to play any game right now although windows seems stable now that I went to a restore point from before the nf2 drivers
I forgot to mention that when it locks up it seems to go back to running normal after 5-6 seconds.
Well unistalling those nforce drivers fixed the lockups in windows but I am still getting them in bfv (must be a different issue?). I think the windows lockups were caused by my usb port (1.0).
Vriess said:
m7ncg
xp 3200
9600 pro
Ok, you've posted some specs, thats good. How about posting the name of you power supply and the amperage rating for each voltage rail.
Also how's your system and cpu temperatures doing?
Later
MD
The power supply is a turbo link 350 atx. I no longer have any issues with windows hanging up (strange). But now I am having trouble running any game. (Im guessing this is the same problem)
Some games I just click and its like nothing happened while others will freeze inside the game. I dont think its an amperage problem since windows is running fine? Where would I get the ratings you are looking for? Off the bootup screen? To me this does not seem like a power supply problem although I would not really know.
It might be the video card (or the interface with the vc). I get freezes in games and I have had my monitor go orange a few times in windows which caused me to restart (sounds like the vc maybe)? I know this pro is in good shape though.
As for the temps I have no way of checking them but the sheer number and quantity of problems points to something else.
Thanks bud
Todd
Im having trouble running any games now. Doom 3 will run but only once every 200 clicks (it says it needs to close) and bfv is useless.
When i try to download the unfiied drivers for nforce mobos from nvidia I get hangups in windows that last from 10-15 seconds. This seems like it is related to the problem.
It could be that the power supply is faulty but im guessing this is eithier a mobo or chipset problem.
okay. your problems can be attributed to many things. the only thing you can really do to troubleshoot this is to go down the list and try to rule stuff out - sometimes, its as simple as re-seating the hs, and sometimes, it can be a lot more difficult [i.e. replacing parts].
first of all, download mbm here and post your temps. overheating can cause many problems like what you are saying - freezing, random reboots, etc. are you using a retail hs or is it an aftermarket one? check to see if your hs is seated well on the cpu, and make sure you use a quality thermal paste like as ceramique or as5.
have you tried formatting your drive, taking out everything except for what is essential, boot up, and see if you get any errors? if you dont, keep adding hardware on piece by piece until you find what the problem is. are you sure your ram is totally compatible with your mobo?
last of all, it seems like you dont think the culprit is the psu. it might be and it might not, but more times then not, having a crappy psu is the cause of all the problems that you are having. look at this article.
here is an excerpt...
Symptoms you are, or may experience, pertaining to a PSU problem are as follows:
· Any power-on or system start-up failures or lockups.
· Spontaneous rebooting or intermittent lockups during normal operation.
· Intermittent parity check or other memory-type errors.
· HDD and fan simultaneously failing to spin (no + 12V) (is this your systems symptoms too)
· Overheating due to fan failure.
· Small brownouts cause the system to reset.
· Electric shock felt on the case or connector
· Slight static discharges disrupt system operation.
· Removing devices eliminates problem.
it is pretty old, but it does a good job at explaining why a quality psu is necessary. thats why IMO, the first thing you should check is your psu. it seems as if your psu is capable of booting up windows, but everytime you want to do something [like play doom3], and the cpu load gets higher, drawing more power causing an amperage spike. this causes random reboots, crashes, and shutdowns...
