I'm not totally sure if this belongs here, but... if I am using handbrake to convert x264 files to mp4 with the 360 preset will I lose any visual quality? Reason I am doing this is, because I rather stream the movies to my 360 than from my desktop to my laptop and connect it to my t.v., then I can't use my remote.
I've converted normal DVDs I have to mp4 with the 360 preset in 480i and they look decent and only took 1 hour to convert; however these blu-ray/hd rips take about 2-4 hours. I'm just curious with that preset if they will loose their HD quality of 1080p.
Thank you!
4 hours is a long time.. on a quad 6600 @ 3.2 it even seems.
Thank you!
