Format _C:
- Jun 12, 2001
I am having a weird problem (again) with HandBrake
I am trying to encode a ripped decrypted DVD (Final Destination From the year 2000).
The error is apparently caused by the chapter list (The movie will encode fine as long as I don't add the chapter markers which I obviously want)
I have the chapter list
http://webpages.charter.net/formatc/images/Misc_Projects/Final Destination - Chapter List.csv
and here is the error message
http://webpages.charter.net/formatc/images/Misc_Projects/HB_Err.txt
Does anyone have any ideas on how to get the movie to encode with the chapter list intact?
Thanks
Thanks
Code:
An Unknown Error has occured.
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at HandBrake.ApplicationServices.Utilities.QueryGeneratorUtility.ChapterCsvSave(IEnumerable`1 chapters, String filePathName) in C:\HandBrake\hbworkspace\workspace\Release_WindowsGui64\HandBrake\win\CS\HandBrake.ApplicationServices\Utilities\QueryGeneratorUtility.cs:line 1121
at HandBrake.ApplicationServices.Utilities.QueryGeneratorUtility.ChapterMarkersQuery(EncodeTask task) in C:\HandBrake\hbworkspace\workspace\Release_WindowsGui64\HandBrake\win\CS\HandBrake.ApplicationServices\Utilities\QueryGeneratorUtility.cs:line 927
at HandBrake.ApplicationServices.Utilities.QueryGeneratorUtility.GenerateTabbedComponentsQuery(EncodeTask task, Boolean enableFilters, Int32 verbosity, Boolean disableLibDvdNav, Boolean disableQsvDecode, Boolean enableHwd, Boolean enableOpenCL) in C:\HandBrake\hbworkspace\workspace\Release_WindowsGui64\HandBrake\win\CS\HandBrake.ApplicationServices\Utilities\QueryGeneratorUtility.cs:line 137
at HandBrake.ApplicationServices.Utilities.QueryGeneratorUtility.GenerateQuery(EncodeTask task, HBConfiguration configuration) in C:\HandBrake\hbworkspace\workspace\Release_WindowsGui64\HandBrake\win\CS\HandBrake.ApplicationServices\Utilities\QueryGeneratorUtility.cs:line 48
at HandBrake.ApplicationServices.Services.Base.EncodeBase.SetupLogging(QueueTask encodeQueueTask) in C:\HandBrake\hbworkspace\workspace\Release_WindowsGui64\HandBrake\win\CS\HandBrake.ApplicationServices\Services\Base\EncodeBase.cs:line 343
at HandBrake.ApplicationServices.Services.Encode.Start(QueueTask encodeQueueTask) in C:\HandBrake\hbworkspace\workspace\Release_WindowsGui64\HandBrake\win\CS\HandBrake.ApplicationServices\Services\Encode.cs:line 191
at HandBrake.ApplicationServices.Services.QueueProcessor.Start(Boolean isClearCompleted) in C:\HandBrake\hbworkspace\workspace\Release_WindowsGui64\HandBrake\win\CS\HandBrake.ApplicationServices\Services\QueueProcessor.cs:line 460
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Caliburn.Micro.ActionMessage.<.cctor>b__d(ActionExecutionContext context) in c:\Users\Rob\Documents\CodePlex\caliburnmicro\src\Caliburn.Micro.Silverlight\ActionMessage.cs:line 289
at Caliburn.Micro.ActionMessage.Invoke(Object eventArgs) in c:\Users\Rob\Documents\CodePlex\caliburnmicro\src\Caliburn.Micro.Silverlight\ActionMessage.cs:line 254
at System.Windows.Interactivity.TriggerBase.InvokeActions(Object parameter)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
