I am using Handbrake (Windows) to encode TV shows from my Tuner.
But sometimes lip synch is off, just enough to be annoying. Not always.
I think it is hiccup at the beginning of the encode that throws things off. Since I notice it happens a lot more if don't trim before encoding (using the seconds counter), but it still happens occasionally when I trim the beginning.
If I playback in VLC the sync is fine, but play in MPC-HC or Pot Player and the synch is off by the same tiny amount.
Any thoughts on how I can fix? Better software?
