half size video card
compwarez
i want to know which video card that is half size video card.
i got evga 6800Gt and it is full size. i got matx board.
i want at least 6800gt pcie.
I dont think they make "half size" video cards, if your talking about length. Just about any video card should fit in your case unless of course you dont have enough room and cant fit a "dual slot" card.
i am about to buy matx case for it . i know that matx case will not fit on the video card.
Unless your 6800GT is extra long, there is no reason why it will not fit if you have a standard Micro ATX mobo or case. Now, if your case has low-profile slots, then that is different altogether. If that's the case, I think the best low-profile card you can get is like the 7300GS...
Any regular video card will fit in the Qpack provided it isn't extra long... in fact, I see no reason why your 6800GT shouldn't fit... my dad's case is a Qpack and from a quick eyeball, even a 7900GT might be able to fit.
do you mean lengthwise or width-wise? either one wouldn't come in 6800GT form
if it helps, I had an x1800xt running in a qpack with no problems at all......
