Half Life 2 $35!!!!
amohedas
The cheaper one is an import, which usually means theres no multiplay
yes there is multi play in the imported ver altho i cannot say if newegg carries that ver. i have a imported one and i play DM+CS:S fine online.
one review says it comes with source...
I'd order it if I knew for sure though...
I have import and I am able to play CS:Source, HL2: Sourcse.. yay multiplay! :D and some other crap..
Looking for a Canadian deal... It's $58 CAD here. That's close to $48 USD.
Any tips?
It's a UK or other version. It's the exact same game, same CDs, just a different packaging box.
i have the import and the only difference is that the game comes in a bigger box (the ones that games used to come in before they shrunk them).
So by purchasing the import version I won't be compromising single player or online play??
Just want to be sure before I purchase it.
Thx
Why would there be no multiplayer? Multiplayer comes with HL2. You just have to download it off of Steam. Unless of course, the "import" is some kind of warez version but I like to think that newegg is better then that. :D
