Half life 1 on netbook
  • Thread starter Deleted member 89137
  • Start date
D
Guest
Soo I have this Gateway netbook with an intel atom n270 and some 945 intel extreme graphics chipset. I am trying to play HL1 on it and I get about 20fps. I havn't really messed around with any of the settings, but has anybody managed to get this game playable on a netbook or similar crappy hardware? I'm running the game at 640x480 in openGL at 16 bit. Havn't changed any console settings, the intel drivers are the latest for the EXTREMEEEE chipset, and all the settings are turned as low as they go. Starting to give up hope on any sort of gaming on this thing, going to try playing diablo 2 on it... these things are worthless.
Shoulda got the nvidia powered netbook :mad:
What, you were expecting to play Crysis on a netbook?
Com'on dude. It's a netbook.
I've played Diablo2 (playable but slow) and some older shooters like Q1/Q2/Unreal1 (flawless) on a netbook (the S10). The performance cutoff seems to come after any game from 2000-on, like Q3 barely runs. That means HL1 should work, havent tried it myself. When I feel like gaming on it while traveling I usually play BG1/2 or starcraft1.
Dood, welcome to the 90s. I can play Zelda: OoT via Project64 on my lappy (Intel Mobile 4) with rock-solid 100% fps. I remember when hardware struggled to get decent framerates for N64 emulation.
Isn't Half Life less demanding though?
Yes, it is. I used to get higher fps in halflife and 20-25 in zelda on my old k6-2 / voodoo 3
True, netbooks are pretty crappy. I'd rather work around on my Iphone at that point usually.
That's hard to believe, I got better performance on my Celeron 300a @ 450 with Nvidia Riva TnT 16MB (was able to run at 800x600).
Switch to Direct3D rendering. Intel might be putting more effort into that than their OpenGL drivers.
Also, you could try editing the config files.
That game should run good on that netbook. I would look at other issues: too much stuff running in the background, too little free memory, etc. Run D3D rendering. Are you using a wireless mouse? Go wired. Something like that.
I feel stupid, I changed the sound quality to low and my FPS doubled. hurray, its playable!
Diablo 2 is fully playable if you play in windowed mode. I believe it forces it to use directdraw instead direct3d. I play it on my Viliv S5. It is a 4.8 inch tablet PC. 1.33 atom, 1 gb ram, 60 gb hard drive, GMA 500 video card. It even has 1024 by 600 resolution. That is some insane pixel density.
