QuadDragon
- Jun 26, 2007
I recently decided to puchase 2 Haier LE55B1381 to use for my Nvidia Surround Display setup.
Turns out it was a mistake. It appears the TVs have some input lag which is driving me Crazy. I've posted this in the Nvidia card section but I wanted to repost here in the Display section and see what you all thought.
I wanted to pose to you all the same question.
What do you all think of the LG 55LS4500 55" 1080p 120Hz Edge LED HDTV
Here is my last post on my thread.
Well I hate to say it, after one day of use I have called Amazon and arranged to have the TVs picked up. I am however going to replace them with something with less input lag.
I have been checking out http://www.displaylag.com/display-database/
I found http://www.amazon.com/dp/B0096FBBK8/?tag=dislag-20 which are pretty close to the same price range.
The thing I noticed most about the Haier is the soft feel of the mouse when I move it that I just don't get on the Samsung TV.
My wonderful Naga Epic feels imprecise and laggy on the Haier. I have also noticed visible lag mostly vertcally. Say I have a window open and I am dragging it down and its split between one monitor. The samsung will move part of the edge down then the Haier will hurry up and play catch up.
So for all you input lag people talking about monitors vs tvs, What are your thoughts on the LG? Do you think I will see better results or am I just wasting my time?
