Hai! I need to read rules!
Status
Not open for further replies.
That case would be worth that if it came with 2 $100 bills taped inside the side panel.
Hey, remember that Thermaltake is trying to sell their Level 10 wall decoration for still more!
What you're getting here is a revised/customized Lian Li PC-X500 case, which normally retails for about $350 give or take. The hard drive cages have been moved down to the bottom, 2.5" SSD cages added, the 120mm fans have been rearranged (3 front intake & 1 rear exhaust now instead of 2 & 2 originally) and 2x 60mm fans added to the lower component.
Whether you think these slight modifications and private labelling of the ABS name are worth the roughly $150 will likely depend on whether you think the original X500 was worth the $350 to begin with. It does seem like a hefty premium for these minor changes. I wonder if LL will release one under their brand name.
no implied cursing in thread titles, no shouting (all caps) in thread titles, and excessive exclimation points are unnessicary :p
Status
