HAF932 side door depth?
Ludovic
Hi All,
I'm looking to mount 2 x 240 rads on the inside door of the HAF932 simular to the one shown half way down this thread http://www.evga.com/forums/tm.aspx?m=200522.
Does anyone know the maximum combined depth of fan and radiatior block I can squeeze inside?
thanks for reading
Ludo
It's not the side door depth, rads are fitted over the motherboard area. From that pic it's evident that about 2" worth of space is available, but you might be better off asking in that thread, the poster of that setup. Personally, I just hang one rad on the top and and one outside, behind the case, and top portion has plenty of room for PA120.3 and 6 fans in push-pull
Thanks...
I would have asked the original poster, but that thread is nearly 2 years old and that was their only post...
I was hoping to mount two XSPC RX240 Dimensions: 125x58.5x286mm (WxDxH) plus fan on the inside of the door, I'm guessing I might be hitting the top of the video card, if so I might have to choose a thinner radiator.
any further help would be grateful since this will be my first WC build.
Ludo
