HAF932 - changing fans
Technophobe
I would like to have the large red LED fans for the side and top of my case as well (in place of the standard black ones).
The only ones I can find locally are these:
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_601&products_id=11310
Will they fit Ok? I think the originals are measured at 230x200 (slightly oval shape) instead of the round ones above measured at 200x200.
I would rather not have to drill extra holes etc.
it looks like that fan youre looking at has holes for 2 different mounts, so i would assume it would work. whats the distance between holes on your case? measure both the x and y distances in mm. it looks like that fan youre looking at has holes for 2 different mounts, so i would assume it would work.
