HAF922 fan filter
Hulk
Where can I buy a filter for the giant front fan?:confused:
Does anyone on here own this case?......................................................
I do and there is a screen filter inside the front mesh, but it's a pain to get at. There are 3 screws down each side on the inside of the case, and you have to lift the top panel where the front panel connectors are in order to remove the front panel completely. I actually cut of the crossbar that crosses under the the front usb connectors and leave the screws off so I can just slide it out when I want to clean it out. The downside is without that bar at the top, the front loses rigidity when you take it of so all the front panel covers tend to fall out. Once it's back in place on the front, it's relatively secure, never had it fall off on it's own, even while moving it.
