Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Guess that depends on what you're putting in it. The CM690 only supports up to ATX size, while the HAF X will also accomodate E-ATX, which many mobos are - more so when Haswell gets rolling real good. Also the CM690 has less airflow and fewer expansion slots. These things may not matter for the build you're planning now, but if you'd like to purchase a case that'll support current hardware, as well has hardware many years into the future without worrying about a case upgrade, go for the HAF X.
