HAF Stacker and Radiator positioning
bigrigross
I just purchased a HAF Stacker 935 case. This will be my first liquid cooled build. What I want to know is where I should put the 915 pedestal. The 360 rad will be in that along with a push pull fan setup in it. Should I put the pedestal section on the top or the bottom of the case?
I am getting the XSPC Raystorm 750 EX360 watercooling kit. It has the built in radiator/reservoir in a 5.25 bay system. I would like to put the radiator section on the bottom of the case because I would like to pick up a second 915F case for a seperate LAN system. Will the distance from the radiator to the 5.25 bay pump be too much strain for the pump? I am a complete noob on this stuff and I have done tons of research on this, but I couldnt find an answer for this. I know I will need more tubing for the bottom mount than the top mount. And this system will have 1 cpu and 2 gpu blocks. I appreciate any help yall could give me. Even pointing me to thread would be helpful.
Thanks!
