Haf 932 Window mod finished
Cheers JP, just a bit of touch up work and then I think im finally happy with my new PC.
Temps are really good, even after playing mw2 for a couple of hours they never get above low 60's
That looks great. I thought about putting a window on my Haf 932, but I bought the AMD edition Haf instead. Soon as I get the paint finished I will post pics.
hey gueys, im new here but a long timer member at other forums under Antipesto93
I just did a similar window mod on my Coolermaster storm scout, and replaced the tinted window with the clear acrylic window, its alot better now, what did you use to cut and stuck your window?
Hey Cryptic,
I used a dremel to cut the panel and scoring to cut the acrylic and then bolted the window in place. and as for dust..well we will see..maybe it will add to the look :)
