haf 932 fan question
Rustic
Just built a gaming rig in this case(slightly older version). I have the top fan and front fan on the power supply and the rear fan on the MB. The top fan seems to be moving too slow. I am worried when I am playing for a while it will need to go faster.
How should I have hooked up the fans or is this normal?
Thanks for your time.
Are you referring to the 200mm/230mm fan up top?
Just keep in mind larger fans can run at much lower RPMs and still move a good amount of air. If that one fan is running much slower then the other fans of the same size in your case, you could have a faulty fan. I run all of my 200mm/230mm fans from my psu.
With the other fans in your case, you shouldn't have overheating issues related to air flow, even if that fan isn't working at all.
I bought the case used about a year ago and am just getting around to building it. So if a fan is hooked up on the PSU then it should be running full blast, correct?
