HAF 922 x58 Build
Rucker61
I spent some time looking for the right case for my x58 build. Costs quickly dictated that it would have to be an aircooled solution, and I wanted something that would fit in the 21" vertical space in my recording desk. After my research I decided upon the new Cooler Master HAF 922. It's a good looking case but, like some, I really didn't care for the non-black interior. I've read enough here to see that a simple paint job with some Rustoleum should solve that problem.
I have just completed an Antec 300/AMD build that I also painted. The Antec was easy enough to mask prior to painting, but when I looked to do the same with the HAF I realized that masking wouldn't be so easy. I was considering disassembly and researched here what that (and reassembly) would entail when I realized I already own a rivet gun. How hard could it be, right?
Before:
Doors off, ready for drilling out of the rivets:
Drilled apart:
Interestingly, four connection points were screws, not rivets, and they held the top of the motherboard tray to the case.
During:
Primed with one coat Rustoleum primer:
First coat of paint:
After:
Reassembled, waiting for parts.
Parts:
EVGA x58 SLI Motherboard
Intel i920 D0 CPU
3 x 2 OCZ Platinum 1600MHz RAM
Corsair 850TX PSU
EVGA 275GTX SLI
2 x WD 74GB Raptor RAID 0
WD 320GB 7200RPM HDD
HP DVD writer
6 Scythe Slipstream 1200RPM case fans
Megahalems CPU cooler
More to come.
I chose this case for pretty much the same reasons. Sadly, I was too impatient to paint it 1st, but I think I would still like to. Was it difficult to re-rivet it and keep everything lined up?
Now I wish I painted mine....
You'll have to tell me how those scythe slipstream fans sound relative to stock cooling...I've been meaning to replace or just add a couple fans to my case.
