HAF 922 SSD Mount
PiERiT
So I grabbed an SSD today. It came with a 2.5" to 3.5" adapter, which I installed. However, I can't sort out how to install it into my HAF 922. Is there another adapter I need to buy, or am I overlooking something?
Thanks in advance.
Picture of the 2.5 to 3.5 adapter? it should fit into a normal hard drive slot.
Edit: Wow, it seems I'm a bit thick. I had the adapter on incorrectly. It fit so well the way I had it, I thought it was right. :(
Thanks.
