HAF 922 Optimal Air Flow
Hulk
I have a HAF 922 case, it comes with:
1 front intake 200mm fan
1 top 200mm fan
I installed a Zalman 320 with two Noctua fans in push/pull.
I also have 3 extra 120mm fans. Where should I place them for optimal air flow? I put one of them on the bottom of case for intake, I put another one in the space where there is room for 5 5.25 drives as intake, I suspended another one right under the RAM blowing up.
I'm not sure if I used too many fans or not. My temps while playing BF4 for over an hour maxed out at 51 degrees.
