Had a clearance problem with my H20 setup
dR.Jester
I installed my new LG Blu-Ray burner today and cut it damn close. The drive is about a 3/4 of inch longer than my previous IDE burner (Samsung). The power adapter got in the way and prevented the drive from being fully installed. I managed to create an easy compromise and simply moved the radiator back a notch on the mounting bracket. That worked but will not be a permanent fix. Here are a few pics:
As you can see on the photo above, the outlet port on my radiator had a clearance issue prior to being moved. The SATA power kept pushing up against where the tubing is on the barb. :(
Here is an overview shot of my CPU block...
The outlet is now in perfect alignment with the radiator inlet port.
and lastly, a shot of my new LG Blu-Ray burner and water cooling reservoir.
and yes I know I need to dust, its on the to-do list however it has been too cold and rainy to take PC outside.
Case is a Cooler Master ATCS 840 with a Danger Den dual 120mm radiator
