Hacked Max3 Bios anywhere?
sharkdiver420
Hey all,
I still have a max3 and I just ordered this here for my system and wasnt thinking at the time but Im I going to have a problem with the new ram being DDR2 because I cant find anywere weather my mobo will support it..?
2nd..The reason for the new BIOs is im hoping may be around so I can bump up my ram volts too 2.75 or just 3.0v to power the new sticks and to do a bit of overclocking I hope.
Anyways thanks..Im at work now and have to go.
Shark
the Abit IC7-MAX3 is a DDR mobo.
it will never work with DDR2 stix b/c they physically way to big to fit into a DDR slot.
as far as I know, the only way to get higher stable voltages is with a voltage mod that you ahve to fix on the mobo itself, its not a BIOS issue, its an actually problem with the mobo.
Thanks for the replys..Now Im bummed :( ..Ill have to return it when it gets here wednesday..
Thanks,Shark
