H97 based Mobo - good enough for my needs?
I have always been a little unclear on what the differences are between motherboard architectures so I'd like to check the board before I tale the plunge.
I need this basically as a minimal workstation with focus on video playback and portability - but laptops just don't work in my application. It supports 3 monitors which is a major ++.
ASRock H97M-ITX/ac LGA 1150
The device has this: 1 x Vertical Half Mini-PCI Express Slot: For WiFi + BT Module
-Can this be used for some other card as I don't like wifi or BT on this machine. I have a lot of dual nic's that only take pcie_1x and I'm wondering if I could use some kind of riser where the wifi card would fit.
I do need 2 other Gigabit metwrk connections. I'm thinking of a USB3 hub/nic combo as one option along with another hub/nic or a stand alone USB nic.
I have a lot of dual nic's that only take pcie_1x and I'm wondering if I could use some kind of riser from the wifi/BT slot to put the pci-e x1 card in?
If all else fails I have seen risers that split a x16 slot into something like 4 x4 slots which might be an option.
Anyone have any ideas on how this mini pci-e slot can be used and what CPU would be a good choice for $120 or less?
Also, i have G Skill DDR3-1600 / PC3-12800 4GB sticks of ram. Any reason why this wouldn't work on this?
If you are going to mess around that much with risers and splitters and such, just get a M-ATX format or even ATX format board, especially if you don't need all the bells and whistles that board you listed has.
I looked into a M-ATX but the reason I wanted a ITX is because I wanted a small case that I can transport fairly easily.
I own this motherboard paired with an I5 and 4590 for the fiancee's computer. She loves it. Does skyrim really well with a Geforce 960.
The H models have a small amount of features missing, but nothing I notice that's worth of note.
Would a G3258 work for you overclocked to 4.5?
