The top has the 140mm blowhole, but not sure how much room is needed around the motherboard,etc. Anyone tried this? Haven't found anything but maybe my google-foo is weak.
It may work, but there are usually a lot of things at the top of a motherboard that will make it a bit difficult. It might run into the 4/8pin power connector and motherboard heatsinks. You may be better off with a dual fan thick 80mm radiator like an H80i.
