I received a SuperMicro 2U 2x1200W chassis from a forum member. It only has 2 EPS12V 8-pin connectors coming off the redundant power supplies, but my H8QGL motherboard requires three. I was thinking of using this chassis instead of the Blackhawk Ultra case once my board gets back from RMA.
1200W is plenty to power my 4P G34, but the lack of 8-pin connectors makes me wonder...
Since my motherboard requires 3 8-pin connectors for best power delivery, I was wondering how bad it would be to use on of these EPS12V Y-splitters?
EDIT: In doing some research, it appears each pair is good for 7A, so 28A for the 8-pin connector or 336W at 12V. I imagine I could even put a 4P 2011 board in this chassis and use two of the splitters since the X9 boards have 4 8-pin connectors. Thoughts?
