h80i and antec 900?
altjx
Does the h80i liquid cooling system work with the antec 900 computer case?
I'm having a really hard time trying to get the radiator in there because it's touching up against parts of the motherboard and I don't want to? try forcing it in there. has anyone else got this to workwithout trying to drill holes and crap
can you post a image of your case? you should not have any problem with any of the motherboard parts... the most problem in that case with an h80/h80i its the side panel..
Ok, I got it connected juts fine now under the motherboard. However, now I'm having issues getting the brcket to screw/touch the standoff screws that are connceting the other bracket which is underneath.
the backplate should be mounted this waycheck at the 2 marks should match the 2 CPU socket rear screws... like the picture.. its not noticeable but the backplate have unique mount way, thats why are marked
read this
PS: if the backplate its a bit loose while mounting the backplate and the standoff do not worry..it will be pretty tight when all the kit its mounted
Got it!!! Unfortunately, I had to sacrifice one of my LED fans because the cooling system's fan took up the last 3-pin power port on the motherboard.
Is there another way to go around this? Lol
if you check the 3 pin power connector that out of the water block.. it have only one cable.. it just use one pin right? that pin should be connected in the CPU_fan header on the motherboard and its to report the pump RPM to the motherboard to avoid the issue of "CPU fan error, please check".. no other fan header its needed to run the H80i/H100i. you connected both fans to the water block right?...
