H80 - Taunt Cables
Well if the cables didn't pop off during the rigorous shipping, then I really doubt that it would come off while it's installed. Just make sure that they aren't being pulled or are in a tight loop that would put pressure on the end-points and you should be good.
Take a pic and post it? You should be ok if the hoses arent kinking.
Also, there is no 'N' in taut.
Yeah, those corrugated hoses are stiff, but they are pretty rugged.
Now you just need to see how far you can push that Ivy with it :D
