- Jan 9, 2012
I just purchased an H60 and an Asrock z77 itx board. I will be running the cooler in push pull config and would like a third case fan to cool the motherboard components. The problem is that ITX board only has 2 PWM fan connectors. I found http://www.amazon.com/Silverstone-Tek-Sleeved-Splitter-CPF01/dp/B00B46XKKQ/ref=sr_1_1?ie=UTF8&qid=1366752726&sr=8-1&keywords=silverstone+y+splitter
Would work great for both H60 fans (I also got a stock H60 sp120 2000rpm pwm fan from corsair) but will it work with the H60 3 pin pump and a corsair sp120 that also has a 3 pin connector?
I did some research and the H60 pump uses 0.1Amp so power shouldn't be a problem. One of the connectors on the splitter is missing the 3rd pin. How will that effect the 3 pin connector?
Sorry if this is a newbish question but I googled and couldn't find a definite answer.
Thanks for your help.
