As someone else already pointed out, mITX can only accommodate one expansion slot.
Search for mini-DTX for two-slotted solutions. Keep in mind, though, that mini-DTX is a rather new standard, and not very popular at it (funny enough, there seem to be more Intel-based mini-DTX motherboards than AMD-based, and AMD created the standard... lol).
I didn't think it was all that new, perhaps my memory fails me.
Intriguing, I didn't realise there is more Intel implementations but it doesn't surprise me!
Exactly. That configuration, though it would make sense in some implementations (especially on Atom-based motherboards), would cause A LOT of headaches both to motherboard and case manufacturers. No case currently available can handle using the motherboard I/O bracket as an expansion slot. And I'm guessing manufacturers don't want to spend the extra money on ultra-niche markets...
This is a good point, I'll still hold out hope that a freak appears, but in the meantime I'll just have to resign myself to mATX
Give it time. mini-ITX took several years to be accepted by the mainstream audiences. I remember the first VIA Epia mobos a very long while ago.
Mini-DTX is the same thing: it was created by a low-volume manufacturer (AMD doesn't even build motherboards, and CPU market share is still nowhere near that from Intel, though calling AMD a low-volume manufacturer when comparing it to VIA is kind of stupid, I know), to be used on a niche market. It will take time, manufacturers are just now getting the hang of things on the mini-ITX camp...
I suppose, I could've sworn it's been out for at least 2yrs now..
That's a pretty good indication that it'll prolly never get any critical mass
However, there is something mini-DTX has against it: the fall of the expansion slot market. Let's face it, back in the days you'd need a GPU, a NIC, a Sound Card and probably a couple other non-USB expansion cards on your rig. Nowadays, most of that stuff is embedded on something else, or it's available on USB format (for better or worse).
True, but there will always be enthusiasts that aren't happy with the integrated stuff & will want the option for 'discretes'.
Particularly central componentry like graphics and audio....
For the "normal" people among us, if you need a gaming rig, you're probably thinking one single or double-slotted GPU, on-board audio and LAN, etc. Low-end machines can even part with the GPU, so no slots needed there. Anything bigger than mini-ITX here is wasted space, really. Right now, and if the IGP on Clarkdale/Arrandale CPUs is good enough, even entry-level HTPCs can live without more than one expansion slot (and there are even USB TV receivers). Thus negating the need for the more expensive two-slot motherboards...
I'm hoping arrandale will be fine with all HD media formats but the jury's still out.
There's no such concerns with VDPAU + GT210 in Linux.
I'm also not wanting to use on-board audio or digital pass-through to A/V receivers &/or discretes...
I want quality analogue out straight from my front-end, hence the need for another PCI slot for my Essnece ST + H6 7.1 board
On the other hand, high-end gamers, audiophiles and the mid/high-end HTPC crowd need at least uATX, since most GPUs need the second slot space, which mini-DTX would loose, and multiple GPUs and/or dedicated audio/NIC/TV cards need more than two slots.That said, I still hope mini-DTX will triumph. If GPUs can go back to the single-slot era with decent performance, the second slot might come in handy for one internal TV receiver.
Yeah in reality even if I had mini-DTX options, I guess I'd still be too limited if I want to swap-in a beefy gaming card occasionally.
I'm going with the front-end + back-end topology (MythTV)....
My front-end needs to be as integrated and as low power as possible without compromising too much.
Most of the time it will just be: H57/Q57 mobo, 2GB DDR3, i3 530 (or the Pentium), GT210 (if needed), Essence ST+H6, WD black 1TB, & maybe a SSD for boot volume.
I may buy a strong GPU later to swap-in occasionally for gaming....
The back-end will be my PVR and (temporarily) my NAS.
