h50+amd 965 BE overclocking help
ok so i installed my h50 and made sure it was proper installation and my idle temps are around 34 to 35 degrees (cool n quiet enabled) and running prime 95 with stock clock it gets up to the lower 50's. then i go to overclock it and even at 3.7ghz it still reboots my computer, i've monitered the temps and they have never gone over 60 celcius, i think highest i've seen it get is in the upper 50s, like 58 when i tryed to get a 3.8 clock. but it never fails, i try to overclock then run prime 95 then it reboots itself. any ideas?
what voltage are you using on the CPU? and are you using the multiplier to overclock or the HT reference clock(FSB)?
