H2O Info for CPU / GPU Inline Temp Sensor info
M a d c o w
Hi Everyone...
I need some info on Temp Accuracy. As you can see the picture below is similar to what I have. I have Both my CPU and GPu with the AquaComputer Temperature sensor hooked with these on. Base on accuracy on temperature is this accurate as it flows through or Should add a temp probe beneath the Cpu and Gpu block. Curios when I ran the EVGA Precision Tool, it gave a whole different reading base on my Temps.
Thanks in advance
what are you using these temperature values for? fan speed on a liquid cooled loop should be determined by the liquid's temperature, not the component temps.
