H243H vs G245H
ryu4000
Which one to get for surround gaming i hear the h243h is good but i'm not sure if paying extra for the g245h would be worth it need some people that owns or knows alot about monitors to give me some adivce here
Well i dont have the g245h but i have the H243H, and its great. no noticeable ghosting or input lag. I use the trittons, but i use the Astro a40 with the mix amp. Its the same connection set up as the trittons. All u need is an optical cable from the trittons decoder box to the xbox or ps3 ect.
Depends on how much money you want to spend. You can get 3x Acer H243H for 600$+tax here (NCIX CANADA) while a single 120hz Acer is 450$.
Read these reviews
Acer 120hz
http://www.digitalversus.com/article-357-7352-38.html
Acer H243H
http://www.digitalversus.com/article-357-7266-38.html
Comparison
http://www.digitalversus.com/duels.php?ty=6&ma1=38&mo1=625&p1=7266&ma2=38&mo2=631&p2=7352&ph=1
Obviously the Acer 120hz is much faster, also for eyefinity you would never need to have Vsync on which is much easier on the graphics card and gives you a better frame rate. Other wise in terms of contrast/color they are almost identical. It's up to you if you want to spend 1000$+ for 120hz and 3D (which might also be a good investment). I have the Samsung 120hz monitor and love it as I have an older card, and I also plan on going 3D later.
If you have the money go for it as these Acer's are the Pinaccle of gaming monitors right now.
thanks just order the Acer H243H just order one for now get the other 2 next month when nvidia gives me my surround gaming
