H220 replacing H100
Rattle
Does anyone think this is worthwhile? I've been happy with this H100 (original), now that I have a 4770k I was thinking of delidding and getting a better cooling solution.
Does anyone know if swiftech sells the plate that goes over the socket to make a flush surface with the cpu die?
The H220 will perform better and bit silent than h100.. But does not expect a huge drop of the temps...
Also swiftech sell the apogee drive II wich its waaay better than the corsair h100 waterblock/pump...
OP, define "worthwhile" first. How many Centigrade gained separate "worthwhile" from not?
