H20 for 1900xt
I thought about this, but then i read a review about it that wasn't so good.
It wasn't on an x1900 mind. I think i may of been an x850 or similar.
Seems quite pricey aswell.
ya, these new GPU water cooler's are for those who dont know any better.
Read a review in maximum pc about it. It was a decent cooler but you would get about the same temps as on air but with less noise. If noise is your issue I'd go for it but if not... Zalman. I love all of my zalman stuff.
you dont really need ram cooling, as the ram is actually fine without any heatsinks, u can stick som ramsinks on there if u wanna be safe, the VF900 looks like its a good option though
Read the same review, and they said it does nothing for the ram and that they were actually worried the RAM could get damaged from all the heat it was giving off.
