H170 chipset driver
Sparky
Using Acronis Universal restore to dissimilar hardware its asking for the chipset drivers in .inf, .sys or .oem format. Intel and Asrock both have a .exe install file. I have searched and found none. I tried using 7-zip to extract the .exe but that only listed files u1-u100 in mszip format. Any way to find the .inf? Can I copy it from a working system and if so where would it be on Win7 x64?
setupchipset.exe -extract <path>
That command will dump the driver extracts into a folder.
