Hey guys, I just bought a Corsair H100i but since it is a 240 rad, my case, the LIAN LI Lancool PC-K62, should I mount the RAD inside or on top with a push/pull config for the best heat dissipation?
Push/pull intake will give you best performance but I don't think you case have enough room for that. I would say mount the rad on top with 2 fans as exhaust and use the rear fan as intake.
Currently I have a 280 rad that is under the plastic top, fits rads up to 30mm thick. I was going to use my old 280 rad to cool my 7970 and buy a rad mount and mount it on the back of the computer and put the 240 rad where the 280 used to be.
