Building a machine for a friend and he has a AX1200i and H100i.
Problem is that someone convinced him to replaced the H100i fans with Corsair Sp120 fans and now I'm stuck with 3pin instead of 4.
I have a NZXT 5 fan controller in the unit that I'm thinking of now controlling the 4 push/pull fans on the H100i rad.
Yes ideally I should just use the 2 originals or replace the 4 fans with 4 pin but its not an option, he wants the SP120's in push pull on the H100i rad.
Can I go ahead with using the NZXT to control the 4 fans or will the H100i unit get upset?
Thanks ahead.
Thanks ahead.
