Hi guys, I have ported my H100 which has been doing a fantastic job keeping temperatures below 70 on a 4.6Ghz OC'ed 2600k, to a 4770k. 4770k initially had the Intel liquid cooler (some intel rebranded cooling system) which had half of the radiator and only 1 fan. H100 has twice the size radiator and 2 fans. I replaced the Intel cooler because at a 4.5ghz overclock the cores were hitting 80 degrees and I thought I could do better with the Corsair H100. I installed the H100 and even at the high performance mode with all the stock fans going at top speed, my temperatures did not drop. I am still at the 79-81 degree range.
Online reviews show H100 being about 10 degrees cooler than the Intel system but I cant achieve it.
Question is why?
1- I used artic silver thermal paste, but cleaned the surfaces using only alcohol, could be a seating, or the thermal paste usage problem? I am thinking about this because although I do not have a push pull system (just push), when I touch the radiator and the hoses they are cool to touch while the cpu is burning at 80 degrees. If the cooling system was having trouble cooling the CPU down, then it should be warm/hot to touch and not have enough surface area or quality fans to remove the heat away from the radiator.
2-Intel is actually just as good as H100?
3-Something is wrong with my H100?
Question is why?
