sorry to repost, but i posted this in the h100 thread up top but got no replies:
Hi, for those of you using 1155 chipset (i'm using an asus p8p67 evo), did you guys use the shorter screws or the longer ones to mount?
I thought i was supposed to use the shorter screws but i couldn't mount the thicker side of the screw to the mounting bracket so i ended up using the long screws to mount it.
my temperatures seem high, the asus temperature program is reporting 77c in prime95.
Thanks
Thanks
