Hey guys,
Just bought an H100 to replace my trusty TRUE120, I mounted it once and was giving me temps up to 80 degrees. And after reading the reviews here it should be closer to 65... So i proceeded to remount and discovered that I had the backplate on sideways, so I corrected that error and then remounted using MX-2 tightening down in the order which corsair says to, the star or X pattern or what ever youd like to call it. The TIM was applied using the slightly larger than a grain of rice method, and I tightened down incrementally on all corners to try and keep even pressure as it tightened...temperatures are still hitting 80.
Do you guys have any input? should each screw be tightened down by hand on each corner in the X pattern? or do it incrementally like I was doing?
Pump is connected to the molex, and fans (AP-14's) are being run 100% off a fan splitter of the CPU header.
Im feeling defeated here, as ive mounted lots of heatsinks before and usually no need to remount, is it a problem with the unit perhaps? Any healp would be apprciated because at this point my TRUE120 is performing on par with the H100.
Thanks in advance!
Thanks in advance!
