H100 Measurements
Greatone123
Hello, I was wondering if anyone has a H100 could do some measuring for me?
If it's too much to ask for some don't worry about it, but if someone can easily access theirs or has one sitting out would be great.
I need the distance from the outer fan holes to the edge of the radiator. I'm looking at cases and some have limited area around their fans I wanted to see if it fits. I know each fan is 120mm and the entire radiator according to corsair is 275mm. I just want to know how much is on each end after the fans.
Then on the end where the hoses are, could you measure the width? I notice on some rads the area outside the fan mounts is narrower then the actual radiator.
If someone can get me these would be bestest ever, and if it fits I'll post pictures of it when I install it lol.
I'll take the measurements in any standard, but mm would be the easiest to work with and probably most accurate
