H100 in tT Lanbox Lite window?
emerpus
DO you think an H100 can fit inside of a Lanbox lite, where the radiator is outside, cut the side hard-drive holder, move the harddrive cage over more, and having the 2 120mm fans inside? (cutting the window, too)
will it close the option of Sli/Xfire
should i use first-slot pciexpress?
will the tubing fit to the left panel?
