H100 fanspeed
Seireitei
Anyone have experience with H100 fanspeed? For some reason I can't adjust fan speed well to be more specific only one of the fan pin on the h100 works right now it. I used to be able to run all 2 fans on it and the button worked. Now it doesn't work and only one of the four fan connection works. Any suggestions? Right now for both fans on H100 to work I have one on cpu fan and one on the H100 (the one that works). Before I had the 1 wire 3pin to the cpu fan connector and both H100 fans on the H100.
contact corsair, they may just replace it for you if the controller went bad.
