1Wolf
- Jul 10, 2007
I'm going to be using an H100 for a new build I'm working on, and just finished watching a video about installation. It appears that the H100 comes from the factory with Thermal Paste already pre-applied.
What do you guys usually do? Do you just use the H100 as they sent it to you...and use whatever Thermal Paste it is that they put on it? Or do you usually take off the Thermal Paste and use your own (Maybe MX-4 or AS-5?)
If its the later, how do you clean off the paste thats on there?
