Case: corsair 800d
Setup: h100 with two ultra kaze pull air into the air from the top.
I recently changed my setup to have my 2 Ultra Kaze's as intake on the h100 instead of exhaust. People said it would be better to have the top and bottom for intake and the back for exhaust for my case.
Ive been using 6-32 x 2 inch screws with like 6 washers. Is there an actual size screw I should get that will fix perfectly without washers? I recently bought the demciflex magnetic filter
http://www.frozencpu.com/products/1...800D_Magnetic_Dust_Fan_Filter_-_Top_Piece.htm
The filter doesn't sit properly obviously becase i have a large screw washers on poking out. I was trying to see if anyone have any experience with the right size screw for the ultra kaze+h100?
I was also thinking of purchasing two more Ultra Kaze's to do a push/pull.
Should I invest in 4 new fans that offer better cooling compared to the ultra kaze? I dont mind buying 4 new fans.. if it helps. Just need some advice.
Also where do you guys find these 3 pin to 4 pin adapters
http://images10.newegg.com/NeweggImage/productimage/35-185-059-03.jpg < i need some to power my case fans.. a lot of times the fans i buy doesn't come with it. I cant find it on newegg or amazon (prime shipping). Is there another way people are powering these? lol.. besides using mobo / fan controller.
