[h] Psu?
Steeeeve said:
It would run two of your systems...you are looking at pulling under 200watts with that :)
Yeah, but I've never heard of that brand. Is it reputable? Should I go with the similairly price Fortron?
I just edited to post a review of the thing....or rather the brand. I have never heard of it, but that doesn't mean it will stink.
Ahhh the 450bl is back at the egg.
Xclio has the same OEM (Channelwell) that became well known by making Antec supplies.
do yall think that that psu could power:
AMD 3700+ San Diego @ 2.6
MSI Neo4-F
1(mabey 2) 200gb hd
DVD burner
Floppy
2bg ram
X1900XT
bLaCktIGErs91 said:
So if I get it I will NOT be dissapointed?
You shouldn't be but DFI won't give you any support since it isn't 480w :rolleyes:
Narius said:
or what about these
is CoolMax a realiable company?
That question is answered i nthe stickies above ;)
So you're basically telling me I need to get the 480Bl to get support?
No problem if so :)
No problem if so :)
I am saying either will work...DFI is just being asinine with their support requirements. If DFI's support is an issue for you then yes.
I'm not sure about that first PSU you posted, I've never really heard about it or used it. It should be enough to power the system but I am not sure how reliable it is.
Narius said:
I would not trust CoolMax
ThermalTake has been decent in my experiences.. I've ordered some of their mid range PSUs for around 5 different builds.. one died in a power surge but there were no other casualties..
but, for the same price you can get a much better PSU. Check out the stickies for good name brand compaines.
