Dell Small Business has 25% off storage with code KPW79M$LM2PF24
Which means you can get the WD800GD 80GB Raptor Regularly $179 for $134.25
Western Digital Info
Note: Dell has the same drive at many different price points for different systems but should be the same drive for all. Can't imagine why they would be different physically.
Note 2: Unclear about warranty info, will update if confirmed length found.
Note 3: Tech Specs...
Depth: 5.79"
Height: 1.03"
Weight: 1.6 lbs ± 0.1 lbs
Width: 4" ± 0.01"
Average Latency: 2.99 ms (nominal)
Average Seek Time: Read: 4.5 ms
Bytes per Sector: 512
Cache / Buffer Size: 8 MB
Data Transfer Rate: Up to 1200 MBps (Buffer to Host)
Device Type: Hard Drive
Dimensions (WxDxH): 4" ± 0.01" x 5.79" x 1.03"
Dimensions (WxDxH) / Weight: 4" ± 0.01" x 5.79" x 1.03" / 1.6 lbs ± 0.1 lbs
Environmental Parameters: Temperature:- Operating: 41°F to 131°F, Non-operating: -40°F to 149°F; Humidity:- Operating: 5 to 95% RH (non-condensing), Non-operating: 5 to 95% RH (non-condensing)
Formatted Capacity: 80,000 MB
Interface Type: ESATA
Max Operating Temperature: 131°F
Min Operating Temperature: 41°F
Spindle Speed: 10,000 RPM
Track-to-Track Seek Time: 0.6 ms (average)
Type: Hard Drive
Humidity Range Operating: 5% to 95% RH (non-condensing)
Shock Tolerance Operating / Non-Operatin: 65 Gs@2 ms / 250 Gs@2 ms
Start / Stop Cycles: 20,000 (minimum)
Shock Tolerance: Operating: 65 Gs@2 ms, Non-operating: 250 Gs@2 ms
Depth: 5.79"
Height: 1.03"
Width: 4" ± 0.01"
Type: Hard Drive
