[H]ot? Viewsonic va2012wb 20" Widescreen
ype 20.1" color TFT active matrix SXGA LCD
Display Area 17.1" horizontal x 10.7" vertical; 20.1" diagonal
Optimum Resolution 1680x1050
Contrast Ratio 600:1 (typ)
Viewing Angle 160° horizontal, 145º vertical @ contrast ratio > 5:1
Response Time 8ms (typ)
Brightness 300 cd/m2 (typ)
Light Source Long life, 50,000 hrs. (typ)
Aspect Ratio 16:10
Surface Anti-glare
VIDEO INPUT Analog/Digital RGB analog (75 ohms, 0.7/1.0 Vp-p)/DVI-D (TMDS, 100 ohms)
Frequency Analog: Fh: 30~94kHz, Fv: 50~75Hz
Digital: Fh: 30~82kHz, Fv: 50~75Hz
Sync H/V separated (TTL)
AUDIO Speakers Dual integrated stereo speakers
COMPATIBILITY PC VGA up to 1680x1050 non-interlaced
Mac® Power Mac™ G3/G4/G5 up to 1680x1050
[Adapter may be required.]
CONNECTOR Analog/Digital 15-pin mini D-sub/DVI-D
Power 3-pin AC plug (CEE22)
Audio In Stereo mini audio line in
There has been talk about this monitor as well as Cosco being a great place to buy something like this due to their return policy.
Costco's return policy is about as good as an Asian massage therapists' happy ending.
hdcp... it's not even official, yet.
I'd be all over this thing if I could find a review that told me what panel it used and the ghosting level.
I have the 19 in. version (1912wb) on my secondary system and it games nicely. This is an intriguing deal.
.02
"What exactly do you mean by that.... http://www.digital-cp.com/home"
As in, hdcp will only be important if it makes it as part of Vista. While it's expected to be an integral part of the OS, it's not guaranteed yet. Buying only HDCP is much like future proofing against broadcast flags... another rights management scheme that didn't make it.
"LOL. Ever hear of HDMI?"
Yes, obviously, you haven't. HDMI and HDCP are two different things... try doing a search on google. you can teach yourself the difference between an interface and a copy protection scheme...
Thanks, Lawdog. That helps. Do you know what kind of panel (TN, etc) it uses?
Except HDCP has huge support in the consumer HDTV market......to the point of being a 99% shoe in. If you want your panel to double as a HDTV in a year or two like many people do it is something to consider.........
8 ms TN (CPT) panel
From what I could find, this means it will be good for gaming (minimum ghosting) but with poorer viewing angles and a 6 bit panel (16.2 mil. colors), so not so good for graphics.
But, cheap and most likely good enough for me.
Thanks for all the help.
I see minimal to no ghosting in FPS games such as UT2004. Colors are good, but I'd say not as vibrant as a good CRT. Not sure how to describe it any better than that.
How much does a Costco membership cost? If they require a SS# or even a DL# then thats a no no for me..
from costco's site:
Shoppers that are not Costco Wholesale members will be charged a 5% surcharge over the member's posted product prices. If you wish to shop from our Business Center site, you must be a Costco member.
Try again. HDCP is integrated into the HDMI standard. If you have HDMI, then you have HDCP. Educate YOURSELF before correcting someone or else you may look like a dope.
And HDCP already is being broadcast so if you plan on using your widescreen for HDTV then you better wait for HDCP.
Don't listen to the kiddies who are pissed that the free ride MAY be over.
What Do I Use?
I highly suggest that if you are getting ready to buy, make sure the product you are purchasing has DVI connections that are HDCP compliant (all HDMI connections are HDCP compliant). Keep in mind that, although DVI and HDMI are compatible, there is some loss in going from an HDMI source to a DVI display (see below). So, if you are starting from scratch, get all HDMI devices.
link
