Are these that much better that the 485 ones? It's a $35 difference and Iam trying to choose between the two. Thanks!
My friend has the 485's. My 555's are far better.
The AD700s are here!!! (early)
Ok... heres my comparison.
The ATH-AD700 have more clarity but lack the HD555s warmth... the clarity will bring out any flaws in your tracks, receivers or sound-cards. I noticed theres a hiss thats only noticeable with the AD700s coming from my Creative Audigy 2 ZS. I am not sure how to fix it but I think it has to do with the increased clarity and not a problem of the headphones. The hiss sounds like the kind of hiss you'd find in a car tape-deck or while playing blank vinyl but not as pronounced. But I still believe this is not the AD700s fault.
I have read no-where that the AD-700s need a break-in time, but I'm willing to wait. This hiss however is getting quite noticeable on many tracks... I'm not sure exactly what to do, perhaps seek out a better sound card but which... or it could be the source... who knows...
The fit is awkward, they are bigger yet feel lighter than the HD555s... they have an awkward fit and can fall off my head much more easily than the 555s... the cups are huge and get warmer but are very comfortable, even more-so than the HD555s, which is hard to believe. I just really really really wish they could press a little tighter on my head... it feels so light that I can throw them off with a wave of the head.
Bass is clearer but a little weaker than the 555s, which is a bit of a turn off, but clarity can make up for parts of that as you can feel the full range of amplitude of the bass instead of have it leave you deaf half-way through the first bass boom and unable to make other highs out.
In conclusion: ATH-AD700 = clarity (to a fault), HD555s = warmth (to a fault) ... I think I might keep both now, hard to make up my mind.
I got my AD700's this morning. They do not fit me very well no matter how I put them on if I tilt my head down they fall off. Sound Quality at this point does not matter because they do not stay on my head at all. I don't think I am going to be able to use them. I should have got the 555's instead
I think I will try to send them back or else try to sell them without too much of a loss.
Is it possible the AD700's are lower impedance than the 555's? You could try wiring up an adapter to add some more resistance (like 50 ohms) to the cans.
On a side note, the 555's are amazing cans, however, if you really want to hear them perform, get a headphone amplifier. I'm currently using a SOHA tube/opamp hybrid amp for my 555's and they sound awesome. Some times I like to have myself a little toke and just lie there for hours listening, you'll hear your music like you've never heard it before![]()
mine had this problem too. I went into the sound properties and changed the recorder device from Mic to SPDIF or any other plug and the hiss went away. It was strange because even with the mic muted I had a hiss untill I changed the record device....Already posted int he other forum but the rubber band trick works awesome I am very happy now!
Wow, I just got my HD555 in the mail. I bought it when they had two left in stock. Absolutely amazing sound.
Just out of curiosity, how do these compare to the HD-280 PRO's?
I tried playing Bioshock with my 280's and the sound kept cracking.
